Header install on a 95 z
I have a quick question about headers maybe someone can help me with. I wanted to know if i installed the pacesetter race version with out no egr or air can i use it with out a tune and what would i need to do to block the egr and what ever else needs to be done.How long do u think it would take to do the install. thanks
Depends, as long as you keep a good fuse in the AIR circuit, you shouldn't get a code. However, the EGR is a hit or miss. If you get an SES light, then you will have to have it tuned out. You will also need EGR blockoff plates which run around twenty bucks. The install can take a day, or it can take a little longer, it really depends on you.
