header install.
header install.
BBK shorties. 93 LT1
Passenger side header does seem to want to clear the head. I've removed the valve cover but it just doesnt want to go. Should I remove the head? If so, would I need a new head gasket? How hard is it to remove a head?(Never taken them off before)
Re: header install.
You don't want to take off the head to put the header in. You'd need to dismantle the whole top end, take off the intake manifold then unbolt the head and remove it, yes you would need a new head gasket. There is a way to get it in, you just need to find it, go in from the bottom. I found with my MAC headers that an A/C line was in the way so I bent it a little bit and they went in fine.
Re: header install.
I broke my passanger side motor mount loose and had to raise the motor to fit it in on that side i am also running bbk shorties if you need any more help with the install pm me that should make it fit for you.
CARiD
Jul 7, 2015 08:19 AM
