header glow normal???
Old Dec 9, 2004 | 02:09 AM
Getsome17's Avatar
last night I was havin fun doing dounghts on the snow for about 10 minutes. I was looking under the hood after i was done and noticed that my headers were glowing red. Is there a problem with my car or is this this just the headers just getting hot from reving between 3-5k for a little while???
Old Dec 9, 2004 | 02:24 AM
TobyZ28's Avatar
Re: header glow normal???
Header Glow NOT normal
Mine started glowing from a clogged cat. It eventually got worse and worse till i had a big drivabiliy problem.
Old Dec 9, 2004 | 02:50 AM
Bersaglieri's Avatar
Just to repeat for emphasis, header glow is NOT normal. Check out your exhaust make sure no one shoved a potato in you tail pipes when you werent lookin.
-Dustin-
Old Dec 9, 2004 | 06:13 PM
carbed93Z's Avatar
Definetly not normal... Like the others said, I would check for exhaust restriction then maybe fuel delivery, maybe it's running a little lean? I've seen header primary tubes glow red when a motor is SEVERELY leaned out. I would check it out before going out cutting anymore doughnuts in the snow.
Old Dec 9, 2004 | 07:03 PM
turbo_Z's Avatar
Actually header glow IS normal... if you are running excessively rich.
Old Dec 9, 2004 | 09:58 PM
Getsome17's Avatar
Well one of the driver side header header bolts backed out I tightened it up but a part of the gasket missing now so it is leaking some exaust. I am guessing that this is making it run rich, cause it seems to pop a lot more then it did before that bolt backed out.
Ill replaced the gaskets this weekend and see what happens
Old Dec 9, 2004 | 11:05 PM
MEAN LT1's Avatar
How is this so?
Only time IVe witnessed header glow is when the actual motor is Fairly lean.
Old Dec 9, 2004 | 11:09 PM
Red on Red WS6's Avatar
I to thought it was from running very lean.
Old Dec 10, 2004 | 12:17 AM
96formulaLT1's Avatar
it is from running lean, running rich cools down the exhaust charge, not heat it up.
Old Dec 10, 2004 | 12:31 AM
carlos64030's Avatar
I think you have that backwards...glowing headers would come from a rich condition...(excessive unburned fuel).
Old Dec 10, 2004 | 04:02 AM
CoUnTryMuZiCZ28's Avatar
Mine glow red... nice to make breakfast on when your in a rush.. lol.. Yea im running rich as heck too..
Old Dec 10, 2004 | 04:05 AM
Ryan's LT1's Avatar
Header glow comes from a significantly rich condition. Learned that one from Injuneer.
Old Dec 10, 2004 | 05:36 AM
30696bird's Avatar
Maybe the rockers improperly adjusted? If they are to tight it'll cause them to glow.
Critter
Jul 7, 2015 08:33 PM
Russ95Z28
Apr 23, 2015 01:55 PM
ad356
Apr 11, 2015 08:49 AM
QuickSilver02
Apr 7, 2015 11:12 AM
thenewkid
Nov 18, 2014 12:57 PM
