header glow normal???
last night I was havin fun doing dounghts on the snow for about 10 minutes. I was looking under the hood after i was done and noticed that my headers were glowing red. Is there a problem with my car or is this this just the headers just getting hot from reving between 3-5k for a little while???
Re: header glow normal???
Definetly not normal... Like the others said, I would check for exhaust restriction then maybe fuel delivery, maybe it's running a little lean? I've seen header primary tubes glow red when a motor is SEVERELY leaned out. I would check it out before going out cutting anymore doughnuts in the snow.
Well one of the driver side header header bolts backed out I tightened it up but a part of the gasket missing now so it is leaking some exaust. I am guessing that this is making it run rich, cause it seems to pop a lot more then it did before that bolt backed out.
Ill replaced the gaskets this weekend and see what happens
Originally Posted by turbo_Z
Actually header glow IS normal... if you are running excessively rich.
Only time IVe witnessed header glow is when the actual motor is Fairly lean.
