header gaskets installed dry??
Old Apr 22, 2004 | 08:02 PM
BLDun's Avatar
I'm trying to track down a header leak and I have seen it both ways here. Do you recommend installing the gaskets dry or with some additional sealer???
Old Apr 22, 2004 | 08:14 PM
Naegash's Avatar
I didn't use any gasket sealer on mine, and they seem leak free.
Old Apr 22, 2004 | 09:31 PM
hazard2k's Avatar
I have heard from a few people that have used the copper gaskets (dry i am assuming) that they have leaked. They have had better luck with the cheaper gaskets for the headers. Just thought i would throw that outthere
Old Apr 22, 2004 | 10:09 PM
Naegash's Avatar
I used Fel Pro gaskets.
Old Apr 22, 2004 | 10:14 PM
Red96Lt1's Avatar
No problems with my copper gaskets (dry).
Old Apr 23, 2004 | 06:16 AM
97FormulaWS-6's Avatar
I just replaced my Mr Gasket Copper Header gaskets....
They were leaking on 6 out of the 8 cylinders...
I'm now running the Earls (Parker) Polygraphite/Aluminum header gaskets... sealed up perfectly.
Old Apr 23, 2004 | 07:00 AM
scoobysnax83's Avatar
copper gaskets here installed dry and with no leaks
Old Apr 23, 2004 | 08:15 AM
EviLBoX's Avatar
I'd recommend installing the gasket dry. For one thing the sealer stuff makes it messy the next time you want to change your gasket. Also, the sealer stuff is just a band aid for a bigger problem. If your headers still leak after trying several types of gaskets, your header flange may be warped. In that case the best fix is to have your flange flattened.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Fatdog2
Feb 13, 2015 08:19 PM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
