header gaskets installed dry??
I have heard from a few people that have used the copper gaskets (dry i am assuming) that they have leaked. They have had better luck with the cheaper gaskets for the headers. Just thought i would throw that outthere
I'd recommend installing the gasket dry. For one thing the sealer stuff makes it messy the next time you want to change your gasket. Also, the sealer stuff is just a band aid for a bigger problem. If your headers still leak after trying several types of gaskets, your header flange may be warped. In that case the best fix is to have your flange flattened.
