Header gaskets and bolts
Old Nov 7, 2006 | 09:57 PM
69gto96z's Avatar
I am about to order some pacesetter longtubes for my 96 LT1 and was wondering what knid of header gasket to use. I have heard the ones that come with the headers are crap. Also, I am gonna use stage-8 locking header bolts and dont know whether i need the 3/4" or 1" ones. Any help would be appreciated. Also I plan on buying some 02 extension harnesses for my front 02's and was wondering how long of a harness i should buy. I no longer have rear 02's, they have been tuned out.
Old Nov 7, 2006 | 10:04 PM
lt11997's Avatar
I used the fel-pros with my jethots, so far they've lasted over a year and I even used to bolts that jethot sent with the headers.
Old Nov 7, 2006 | 10:08 PM
69gto96z's Avatar
Where did u get your fel-pros from?
Old Nov 7, 2006 | 10:16 PM
lt11997's Avatar
I got them from Summit http://store.summitracing.com/egnsea...115+4294889104
Old Nov 7, 2006 | 10:17 PM
ponyackn's Avatar
You can check with the vendors here, summit, jegs, or locally, just order them from Autozone.
Old Nov 7, 2006 | 10:33 PM
69gto96z's Avatar
Awesome, thanks alot.
Old Nov 7, 2006 | 10:42 PM
95LT1conv's Avatar
get the 1" stage 8s
Old Nov 7, 2006 | 11:07 PM
Daniel6718's Avatar
speedtek ryan, and get the stage 8 with lockwashers so they dont back out.....
go wit the 24 you can always zip tie the extra
Old Nov 7, 2006 | 11:08 PM
69gto96z's Avatar
Damn i forgot about speedtek
Old Nov 8, 2006 | 07:36 AM
2000GTP's Avatar
Fel-Pro 1406s seal very well and are pretty cheap, under twenty bucks for a set. I would go with the 1" bolts over the 3/4, you will get more thread and alot more bite as a result. The flanges on the Pacesetter headers are so thick that the 3/4" bolt gets used up pretty quick. As for the extensions, I originally had the 24" but they are just way too big in my opinion. I swapped them for 12" ones instead and and much happier with the result.
Old Nov 8, 2006 | 08:56 AM
95LT1conv's Avatar
^ i agree on the 24" extensions. i got 18" and they were too long
rick350
Mar 16, 2015 02:59 PM
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
thenewkid
Nov 27, 2014 09:41 AM
