header gaskets??
Old Feb 15, 2005 | 07:20 AM
LT1greenZ's Avatar
header gaskets??
i blew out my old header gaskets....and i replaced em with some cheap paper ones...but a bolt wobbled loose and then i blew the paper gasket apart...soo i decided that i would try the cooper gaskets!! well i got the mr. gasket copper ones for the d-port...and i still have a leak...its quite at idle...but man i give it gas u can really hear it!! soo i let the car warm up....then shut it off soo it would cool down...then i tightened them again...still a leak??? wtf??? should i use different gaskets???
Old Feb 15, 2005 | 09:17 AM
97FormulaWS-6's Avatar
Re: header gaskets??
The only gaskets I've ever gotten to work were the Earls Aluminum/Carbon gaskets. They cost about $40 but they sealed up great, and didn't even require re-torquing.
These were the ONLY ones, I tried just about every other type/brand out there, and these were the best.
Old Feb 15, 2005 | 09:29 AM
1-bad-z28's Avatar
i have used those ones that are 4 or 5 strips of aluminum (maybe stainless steel but it hink they are aluminum) they are awesome. I don't know what brand or anything but they work great
Old Feb 15, 2005 | 09:36 AM
JB94's Avatar
Mr Gasket makes a D port composite gasket in their Ultra seal line and they have worked well for me.Get rid of the copper.
Old Feb 15, 2005 | 09:45 AM
BlownF1's Avatar
If you're blowing header gaskets, you might consider better bolts. As soon as a bolt loosens, no gasket is going to hold up. Standard Fel-pros will work just fine. Without turning this thread into a Breslin bolt promotion, do a search on them and you'll find plenty of info.
Old Feb 15, 2005 | 10:56 AM
LT1greenZ's Avatar
thanks guys....im going to try the earls aluminum ones!!! i have heard good things about them from other sites..thank you guys...and i will look into different bolts
Old Feb 15, 2005 | 10:56 PM
my94blackz's Avatar
I LOVE the felpro gaskett. I cant think of the # off hand but there awesome. There about 30 dollars but well worth it, dont change bolts just use blue locktite.
Midnight_Z
Feb 16, 2016 09:36 PM
dylan1303
May 22, 2015 12:24 PM
4586
Apr 29, 2015 01:43 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
