header gasket question
Old Mar 23, 2006 | 11:11 AM
robwin95z's Avatar
are you supposed to apply any kind of gasket adhesive to header gaskets or just bolt em' in right out the package?
Old Mar 23, 2006 | 11:37 AM
hotrod18_69's Avatar
Re: header gasket question
I just bolt them right in out of the package. .Some guys like to put some RTV around the ports for added seal, but i dont think its nessasary..
Old Mar 23, 2006 | 02:26 PM
CALL911's Avatar
I agree with the previous post. I would just put em in dry. That RTV is going to get so hot it will probably dry and crack anyhow. Plus, the RTV will probably make a mess and not look as nice. Everyone I know has always put the header gasket on without any sealent.
Old Mar 23, 2006 | 03:39 PM
2000GTP's Avatar
I usually put my gaskets on dry. Some people will put some sealant around the ports as already noted or they will spray the gasket with a copper adhesive spray.
Old Mar 23, 2006 | 03:47 PM
Stoopalini's Avatar
If you use RTV, make sure you use the Copper RTV, and not the blue, black, or any other kind.
Thomas.
Old Mar 23, 2006 | 06:47 PM
SloLt1Z's Avatar
I tend to use the rtv since i had a leak once and had to redo it, but make sure it's copper.
Old Mar 23, 2006 | 07:31 PM
hulettsz28's Avatar
you can use some copper RTV, like stated a million times above, but like most others i just put them in with no sealant, just the plain gaskets. works fine.
Sergio
Jan 27, 2016 04:27 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
