Header and exhaust Q?
Old Sep 7, 2005 | 09:26 PM
Resilient94LT1's Avatar
Hey guys! Just bought a 94 z28 and im wondering if its possible to put a pair of headers in there, seeing as how its so cluttered already. (Have to pull the motor?) If so, what kind of horsepower increase am I looking to achieve if I swap the stock exhaust to flowmaster or such as that?
Old Sep 7, 2005 | 09:31 PM
93LT1355's Avatar
Re: Header and exhaust Q?
its quite possible to put headers on our cars and I highly recommend that and exhaust. You shouldn't have to pull the engine to do it. Power increases vary but it is definatly worth it IMO
Old Sep 7, 2005 | 09:44 PM
Thanks man! I appreciate the info, i'm definitely going to do it.
Old Sep 7, 2005 | 09:48 PM
93LT1355's Avatar
no problem. I have a set of Hooker mid lengths that were not to difficult to install and I was pleased with the result. You could also go the Long Tube route but they take more work and customization to get in. Whatever route you choose good luck!
Old Sep 7, 2005 | 10:34 PM
Don't Look Back's Avatar
Headers are definetly a good mod to our cars, I love mine. I personally went with Pacesetter Long Tubes and a Pacesetter Off-Road Y-Pipe. Juat so you know the kind of project you're looking at, it wasn't hard with the longtubes. Had to remove alternator, oil filter, starter, bellhousing shield, dipstick and a few other things such as AIR pump and lines and EGR but those were a personal choice since I went with non emissions headers. As far as "custom" work all I had to do was remove the passenger side heat shield, make a small heat shield for some wires on the passenger side, install O2 sensor extensions, bend the steering linkage a little ******ds, and wrap the fuel and brake lines with heat resistant tape. Wasn't a hard job, just time consuming, but definetly worth it. Good luck with whatever setup you choose.
Keith
Old Sep 8, 2005 | 01:29 AM
Keith
Wow, you guys are incredibly helpful. I can see that i'll be referring to this site a lot in the future! Don't Look Back, that's exactly the kind of info I was hoping to hear, it's going to prove helpful to me. Thanks!
Old Sep 8, 2005 | 01:38 AM
2000GTP's Avatar
Along with a cold air intake and a good catback, headers are also one of the first mods you should look into. Whether you go with shortys, mid-lengths, or long tubes, it is a matter of your preference as well as emissions regulations in whatever state you are in. Do some searches, there are alot of threads about this topic, research really well, and then make your choice.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
drptop70ss
May 4, 2015 08:22 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
92ragtop
Dec 27, 2014 01:56 PM
