Header and Collector gasket question
Old Jul 18, 2007 | 07:47 PM
SteveNof1995's Avatar
Hey guys, I have a dyno tune appointment comming up with FLP. I'm going through the car to tie up any loose ends. I want to make sure my exhaust has no leaks so as to not throw of the oxygen sensors for my tune. I currently have the paper gasket kit that came with my Jet Hots installed on the car with a small leak. I talked to FLP and they recommended a good fiber one. So I need a brand and part number for some good fiber header and collector gaskets. Keys to remember are as follows:
-I have Jet-Hot Long tubes
-gaskets that work for Hooker2231's will work for the Jet Hots as well
-they have an oval style port
~Thanks
Old Jul 18, 2007 | 08:31 PM
speed_demon24's Avatar
I have jethots and every gasket I have tried has leaked on me. I think the fel-pros leaked on me because I never tightened them up after the 1st time I started it though. I'm going to give earls a try this time.
Old Jul 18, 2007 | 09:00 PM
also the key is to tighten the inside bolts first before the end ones so as to not bend the flange outward...good luck
Old Jul 19, 2007 | 08:58 AM
93transam1234's Avatar
I had this problem.
Go with the Earls soft aluminim header gaskets. You can get them at summit.
I put then one once and have had no leaks for over 1 year.
Also you can order just the inserts so if you ever have to take of the headers you dont need to buy the whole gasket set again.
Old Jul 19, 2007 | 11:07 PM
i ended up ordering Percy's carbon composite gaskets from summit....i hope they work (fingers crossed)
Old Jul 20, 2007 | 02:55 AM
wrd1972's Avatar
I have tried nearly every collector gasket and I like the steel core laminate the best. These are what I am using now and like them the best.
http://store.summitracing.com/partde...5&autoview=sku
The aluminum worked decent but I thought they tended to stress and deform the flanges, the coppers IMHO were a total joke cause they were so thin and lacked conformability. They may work fine and brand new perfectly flat flanges.
The steel core laminate type have a certain amount of "plushness" which conforms best to the two flanges. Mine are actuall a tad bent from the aluminum gasket, but the steel core laminate gasket seals perfectly. Pust they are dirt cheap.
Header gasket, Fel-Pro 1406.
Sergio
Jan 27, 2016 04:27 PM
Queens94z28
Dec 20, 2014 09:11 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
