header burnt through my brake line !?!
Old May 19, 2004 | 09:39 PM
Mystic97Z's Avatar
i have jet hot long tubes, and on my drivers side, it burnt through my brake line, i even had my brake line heat wrapped. so i need to relocate those brake lines on my drivers side. has anyone else had this problem? if so where did you re-route yours to? any pics are appreciated. thanks
-Jason
Old May 19, 2004 | 11:22 PM
25thBird's Avatar
I also just installed some Jet Hots on my car, and for some reson mine don't touch the brake lines. They're a few centimeters away, but I just put some heat residtant tape on them just in case. I don't understand how much different our cars can be.
Old May 20, 2004 | 01:45 AM
carlos64030's Avatar
Burned through a brake line?! Do you mean the ABS wheel sensor harness? Headers don't come anywhere close to a brake line on our cars.
Old May 20, 2004 | 01:49 AM
screamin94Z's Avatar
i was thinkin the same thing i cant see the header touching a brake line, and it cant burn through a metal line.
Old May 20, 2004 | 07:02 AM
dreamer1q's Avatar
Actually the brake line going to the rear brakes runs down the driver side frame horn right past the headers. If someone had moved theirs or rebent it I can see it getting to a header very easily.
Old May 20, 2004 | 09:00 AM
bad95z28's Avatar
been there done that. its the line that runs down the side of the driver side wheel well. Mine popped out of the mounting bracket and rubbed up against the primary on the header until it rubbed a whole. you can pick up some cheap connectors at most auto places and it is a simple repair. only thing is you will have to bleed the brakes.
Old May 20, 2004 | 10:56 AM
Spinner's Avatar
Mine was touching when my motor revved. I took a tubing bender and rebent the line until it was plenty clear of the header. I have no doubt in my mind that it would have burnt through eventually
Old May 20, 2004 | 12:34 PM
Mystic97Z's Avatar
it wasn't touching it,but it was about 1/4 inch away when i installed them, and after about a month, the line was singed a little bit, so i wrapped it up in heat wrap, and it still burnt through ?? yes it was burnt by my primary tube.
-Jason
Old May 20, 2004 | 01:14 PM
Perhaps I'm just not understanding, so correct me if I'm wrong. For the most part of the brake line system, the brake lines are metal with the exception of the caliper hoses which are rubber. How can you burn through a metal brake line? The caliper hoses don't come anywhere close to the primaries. If it wasn't so hot outside, I'd go out to the garage and pop the hood on my car to try and figure out what the heck you guys are talking about. When I put my headers in, the only brake related items that I had to reposition were the ABS wheel sensor harnesses. I remember someone else posting last year that his headers burned through a brake line, and he completely lost brake pressure. Still to this day I can't see how that's possible! If at all possible, try to get some pictures taken of the damage and post them so that we can see what it is that you're talking about.
Old May 20, 2004 | 01:19 PM
Spinner's Avatar
Since my motor's out, I'll take a picture of said brake line that's burnt and post it tonight
Old May 20, 2004 | 01:25 PM
The metal brake tubing is under extremely high hydraulic pressure when you apply the brakes - up to 1,500psi. When the tubing it cold, it is able to contain the pressure. When you heat the tubing (header tube metal temps can aprroach 1,000degF - how hot do you think a brake tube 1/4" away will get?), the tubing softens, and bursts under the extreme hydraulic pressure. It doesn't "burn", it more likely "melts". This problem has been reported several times in the past relative to the LT's. The factory puts a thin metal shield over the brake lines that are near the drivers side exhaust manifold. The headers will simply put the hot tubes even closer to the brake lines.
Old May 20, 2004 | 03:10 PM
Gripenfelter's Avatar
I burnt my passenger side front brake line from it touching the first primary on the driver's side when I revved.
Just bent a new line to go farther away.
zxtce
Mar 12, 2015 08:06 PM
jb4xx
Feb 2, 2015 10:00 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
