Which header bolts to use...
Old Jul 7, 2007 | 07:11 PM
Mark B's Avatar
Hey eveyone...
Which header bolts do you guys recomend for my LT1? The headers I am using have a 3/8" flange. I would like to get the locking style so I dont have to screw with them anymore.
Old Jul 7, 2007 | 09:00 PM
user 647483's Avatar
Breslin made very nice bolts. I wish I had known about them when I did my headers.
I don't think they make them anymore. At least, I have not been able to find anyone who still sells them.
Stage8 makes a great setup too (which is what I used).
The downside is that they are 3-peice and can be a pain to assemble.
I've not had any trouble with them. (On my Pacesetters or on my Hookers)
Either way, go with 1" bolts and quality gaskets.
You want as much thread contact as possible in there.
Old Jul 7, 2007 | 10:01 PM
SS RRR's Avatar
What kind of headers? If they're Hooker LT's Stage 8 bolts may work, but I never had luck with them because the locking washers were too large to work. Primaries were too much in the way.
Best header bolt I've used is the ARP 3/8" head header bolt. Either 6 or 12 sided and either 3/4" or 1" in length. You may need to retighten them a few times after the header gaskets shrink from normal heat cycles, but at least they easier to access.
Old Jul 8, 2007 | 08:00 AM
NVetro's Avatar
Besling ALL the way, i've hda them on my new 383 built, i put alittle loctite on all the outside header bolts to see if they back out. NONE have, they are an amazing product. I have the header and collector bolts, I think they were about $45 for the header and like $25 or so for the collector. It seems the US side of the company is now gone, but you can get them here:
http://www.apo.com.au/store.html
MAKE SURE you get the 1" rather then the 3/4", it will help out alot.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
