Header Bolts?
Old Mar 13, 2006 | 09:49 PM
Blackthunder50's Avatar
Header Bolts?
One of the bolts is stripped a little bit and it still holds snug. But the bolts I have are cheap and only .75" long and are non locking. Which set could I get that will definetly hold it all together with some muscle? Will the 1 inch long ARP's fit? The BBK's flange is 3/8 of an inch so that takes alot from the small bolts.
Old Mar 13, 2006 | 10:16 PM
Demon's Camaro's Avatar
Re: Header Bolts?
Get Breslins, thats what I purchased. They are self locking aswell.
Old Mar 14, 2006 | 03:42 PM
2000GTP's Avatar
Re: Header Bolts?
Breslins, Stage 8, or the 1" Arps will do the trick.
Old Mar 14, 2006 | 03:54 PM
disco192's Avatar
Re: Header Bolts?
Seriously... just get 1" bolts and throw some blue (NOT RED!) locktite on it... ive been doing that for a long time and never had an issue.
Locking header bolts are alot like a "tornado" intake... waste of money.
Old Mar 14, 2006 | 04:08 PM
GreenDemon's Avatar
Re: Header Bolts?
I used 1" stainless 12 point ARPs. They have a very small head so you can get a box end on them no problem, and the 12 point helps to avoid rounding. I only had to retighten them after the first couple of heat cycles.
Old Mar 14, 2006 | 10:10 PM
kirschman's Avatar
Re: Header Bolts?
another vote for the ARP stainless steel 1" ones. The have a 5/16 head on em which makes the a breaze to tighten. I would'nt use locktite in and aluminum head. Anything that bolts into aluminum needs anti-seize. Plugs,header bolts etc. Although I do just put sealant on the intake bolts. I stripped the last 2 pass. side header bolts in the head , took the right sized tap and dremeled the taper off of it and they straightened right out, got tight enough for me.
Old Mar 15, 2006 | 07:43 AM
Re: Header Bolts?
Thanks for the replies, I ordered the ARP 1 inch bolts. Thanks
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
