Header bolt question.
Old Feb 3, 2010 | 05:44 PM
Peytons'z's Avatar
I have a exhaust manifold bolt (the rear drivers side) broke off in the head. I have read that this bolt is not used by most headers. Can someone confirm this? It's a 95 trans am btw.
Old Feb 3, 2010 | 06:49 PM
camaronutt's Avatar
That bolt is most certainly used on all headers.
Old Feb 3, 2010 | 06:59 PM
6SpdLT1Z's Avatar
x2. Hopefully it can be drilled out and you don't need to buy new heads.
Old Feb 3, 2010 | 07:05 PM
Kevin Blown 95 TA's Avatar
The broken bolts there are common and they can be removed but it's difficult with the engine in the car. Some guys have welded a nut to it and removed it that way. The ones I did, I pulled the head and it was a pain but they came out.
Old Feb 3, 2010 | 07:24 PM
Peytons'z's Avatar
I sent a email to Lpp after I posted here and they claim their headers do not use it but use another hole that is closer to the exhaust port.
Old Feb 4, 2010 | 01:16 PM
stockssn2o's Avatar
i've had two sets of lt1 headers... slp shorties for 96-97 and jet hot long tubes for 93-95 ... neither use the outter bolt holes like the stock manifolds...
Old Feb 4, 2010 | 04:12 PM
RamAir95TA's Avatar
My LPPs use the inner holes, while my MACs used the outer holes.
Old Feb 4, 2010 | 07:09 PM
Peytons'z's Avatar
I'll be ordering my LPPs in a month or so. Not looking forward to the install at all but I know it will be worth it.
Old Feb 4, 2010 | 07:24 PM
95mysticta's Avatar
Those rear bolts are from i hear are not even tight... how the heck did you break it?
Old Feb 5, 2010 | 04:58 AM
Peytons'z's Avatar
It was like that when I got the car a few weeks ago. I heard a exhaust leak but couldn't track it down till a few days ago. I had to have someone give it gas while I put a hose to my ear and moved it around the manifold. It's only leaking when you get on it hard. Otherwise it's quiet.
Old Feb 5, 2010 | 05:19 AM
Bersaglieri's Avatar
Was swapping headers on my beater camaro and the rear bolt was broke off in the head. I'll let you know which one the Hooker LT's use.
-Dustin-
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
