Head question
Old Jul 19, 2005 | 05:41 PM
1crazylt1's Avatar
Head question
Wanna do work on my heads..tell me if this is good
gmpartsdirect.com
LT4 springs: 12495494
LT4 Retainers: 12495492
LT4 Locks:12495503
1.6 roller rockers..
and do i need to do pushrods?
or anything else i need?
Old Jul 19, 2005 | 06:42 PM
Buttercup's Avatar
Re: Head question
gmpartsdirect.com
LT4 Locks:12495503
I'm assuming this is for the stock cam? If so, those should work fine (though I didn't verify the part numbers). If you use self-aligning roller rockers, you can reuse the stock pushrods. If you go with NA rockers and guideplates, I would invest in hardened pushrods. Some earlier cars came with hardened from the factory, others didn't. $37 hardened pushrods would be fine for the application though
Edit: Get some new valve seals! If you do use guideplates get the GMPP ones (do a search for the part number here)
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
LT14LIFE
Feb 9, 2015 09:35 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Geoff Chadwick
Jul 31, 2002 12:07 PM
