Head Gasket thickness?
Old Apr 16, 2004 | 11:06 PM
a327vette's Avatar
Question Head Gasket thickness?
Does anyone know off hand what the thickness of a stock alum. head LT1 head gasket? How about Iron head? Also some aftermarket gaskets.
I am looking for another couple of cc's (like 10-12) I am going to try to keep the amount I deck the block to a minimum, and I am going to try to get rid of as much in the head as I can and still have them safe and performing well. Figured this is my next place.
Thaks
Old Apr 17, 2004 | 12:04 AM
Eddie95Z28's Avatar
The F-bodies have .049 compressed. The Impalas Are .029 I believe. I am not sure about the other iron headed LT1's
Old Apr 17, 2004 | 11:43 PM
my94blackz's Avatar
I zero decked and im runnin the .029. Just a lil food for thought.
Old Apr 17, 2004 | 11:52 PM
ibanez6rg's Avatar
Fel-Pro replacements are .039, no?
Old Apr 18, 2004 | 12:11 AM
Dave88LX's Avatar
Yessir.
What are you trying to lower compression for?
If you zero-deck it with that .059 gasket you're gonna have a really ****ty quench/squish area...
Do a google or a search on here on 'quench' to see what I'm talking about, it can explain it better than I can.
Basically most sources say you want to keep it between .035-.040" piston-to-head clearance.
You didn't mention what piston/crank/rods you are going with, but the 383 combo that I bought has a 9.000" 1/2 stroke + rod length + compression height. The block deck is 9.025", so you're already .025 in the hole, add a .059" head gasket and you have .084" piston-head clearance...hello detonation.
Old Apr 18, 2004 | 08:11 AM
30thannZ28's Avatar
stock is .039". Impala or b-body gaskets are .029". I went with the Impy gaskets to reduce quench. The only negative I've HEARD of regarding the Impala gaskets is they are meant for a iron block/iron head combo so they don't have the lifespan the other ones have. I think that's just a myth though.
Old Apr 18, 2004 | 08:21 AM
96capricemgr's Avatar
The Impala did not have a special motor, all the iron head LT1s were the same given the same year, and all used the .029.
Old Apr 18, 2004 | 10:26 AM
BPS's Avatar
BPS
Compressed thicknes of available head gaskets
0.028" - Impalla SS (12553160) *some claim 0.029"*
0.039" - Fel-Pro (1074 LT1/LT4)
0.043" - LT4 (12551488)
0.050" - LT1 (10168457) *some claim 0.049"*
Ideal quench is in the .04"-.05" range
Stock deck height is .025" so stock quench is ~.075" crappy but it does work
As mentioned impy gaskets are ment for iron and from all I've seen they seem to have a higher number of blown gaskets than the felpro ones. Not to say you would have problems with them.
I'm just completing a rebuild and kept stock deck height and went with the felpro's on ~11.0 CR motor.
Old Apr 18, 2004 | 04:00 PM
ImpySS's Avatar
There is also a .026 gasket from Mr. Gasket. I use these on my milled iron L.E. heads and 502 cam with no problems.
Old Apr 18, 2004 | 04:10 PM
Dave88LX's Avatar
I thought ideal quench is in the .035-.045" range...
Old Apr 18, 2004 | 05:04 PM
BPS's Avatar
BPS
From my reading 0.035" is an absolute minimum as one has to allow for heat expansion.
so .04" seems to be a realistic minimum .
of course it will also depend on the materials used in the pistons and valves.
Old Apr 23, 2004 | 10:18 PM
Sunsceamer's Avatar
what will the compresion change to by changing just the gasket?
Old Apr 24, 2004 | 01:45 AM
speedmiser's Avatar
Go to https://www.camaroz28.com/calcs/index.shtml
Then find the compression ratio calculator and plug in your numbers.
Old Apr 24, 2004 | 06:58 AM
rskrause's Avatar
Moderator
The Cometic is 0.040", ideal for a zero deck block and a very strrong gasket. I am using them.
Rich Krause
Old Apr 24, 2004 | 09:21 AM
NOMAD's Avatar
The problem with impy gaskets is called brinelling. This is the process where the gasket forms an indention into the aluminum heads. I would stick with cometic or felpro
-Shannon
