head gasket swap checklist
Old Dec 19, 2003 | 12:29 PM
Zack's Avatar
alright, lets see what im gonna need, and where to get it cheapest.
head gaskets(felpro,autozone wants 130 for both, reasonable price?)
intake gasket(which one?)
valve cover gaskets??
ARP head bolts(i read they are good insurance)
i think i've read that you can buy a gasket kit that has all the neccesary gaskets in one...any info on it?
Old Dec 19, 2003 | 12:57 PM
nitropatch's Avatar
Call summit or jegs you can by .039 headgaskets and get a half a point on compression and they only 64 shipped, intake gaskets are like 24 bucks at autozone, and arps are like 55, but the stocks ones work fine but they are 12.95 a side at autozone, so you should spen about 150 or so if you go that rout, or you can get the stock ones which i beleive are like 20 a side but i aint for sure on that just call your local autoparts store.
Good luck
Old Dec 19, 2003 | 07:33 PM
Zack's Avatar
what about valve cover gaskets? are those needed, as well as exhaust manifold gaskets
Old Dec 19, 2003 | 10:03 PM
nitropatch's Avatar
its good to replace the manifold gaskets but you dont have to worry that much about the valve cover gaskets because those are rubber and dont usually go out, buti would get some manifold gaskets their like 24 bucks from autozone. btw is the motor still in the car when you are goin to do this?
Old Dec 19, 2003 | 11:04 PM
Zack's Avatar
yep, the motor is still gonna be in the car. I was looking over how i'm gonna go about getting the manifolds off... this aint gonna be easy. ITs gonna be a few weeks before I can afford the parts, but I Think Im gonna have to start tearing it down earlier than that
Old Dec 19, 2003 | 11:21 PM
AsianSensation's Avatar
Thunder Racing sells complete gaskets kits for just about every install. I'd recommend getting new crush washers for the banjo bolts on the rear coolant cross over tube. Maybe new banjo bolts too depending on their condition.
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
