fuel injectors
Old Dec 19, 2003 | 10:32 PM
BigBobsCamaro's Avatar
fuel injectors
Does anyone know what injectors other than the stock gm multech will work on a 95 z28 without retuining? I had a set of fms 24lb/hr in for a while but they made the car lope when you started it hot. It never ran right with them then I found out you need to tune the pcm for them because they ar rated at a lower pressure. I live in the DFW area anyone want them I'll sell them cheap. Anyone using the ACCELL 26 lb/hr how are those?
Old Dec 19, 2003 | 10:47 PM
You shouldn't need a retune with 24# SVOs (or the related FMS, Bosch, etc.). The stock RP's are input to the PCM as 24.9#/HR. The SVos, corrected for the pressure difference will flow 25.3#/HR.... not enough difference that can't easily be compensated with the long term fuel corrections. I ran 24# SVOs for two years on the stock tune with my "bolt on" setup. Never had any problems at all with them.
Old Dec 19, 2003 | 11:26 PM
blackztpi's Avatar
i've heard stock lt1 was 24lb and 2lb. not sure which one it really is cuz i have an ls1 and 3rd gen car, but i'd go for svo 24lb. don't buy accels. they tend to stick every oncve in a while under longer full throttle runs. lol i hydro'ed my 305 that way a year ago
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
