head gasket change
Old Jan 2, 2007 | 03:11 PM
Mischief_z28's Avatar
head gasket change
yeah, i blew a head gasket, so i think, my car was overheating a drinkin water, so i just narrowed it down to being a blown head gasket, how much do you guys think it is going to run my to get it fixed?
Old Jan 3, 2007 | 10:14 PM
1989CamaroLT4's Avatar
If you do it yourself, not much. Probably $200 or so for a head set, $10 or so for a six pack, and a full day in the garage - two if you pace yourself.
Shop would likely charge well over $500 - $300 for parts and $300-$500 for labor.
Old Jan 4, 2007 | 11:54 AM
2000GTP's Avatar
I would get some offers from a few shops, but I can see it costing at least 800 bucks.
Old Jan 4, 2007 | 04:02 PM
VK's Avatar
VK
Are you really sure you popped the headgasket? If you close to stock i don't think you could pop the stock one if you tried...
Got oil in coolant?
Is your oil turning into mud or have coolant in it?
Old Jan 4, 2007 | 07:56 PM
bingo's Avatar
Make sure you get the heads checked and surfaced if needed.
Old Jan 4, 2007 | 08:21 PM
micfly83's Avatar
I was quoted $2000 from two places when I was blowin a little white smoke out the back.
I changed the oil to a heavier weight and no more white smoke.
I also rag on it daily, and still no problems.
Once it blows, or if it blows, I will definitely be replacing it myself and learning my engine some
Old Jan 6, 2007 | 08:20 AM
pearlpurple's Avatar
Cooling system pressure test
Most auto parts stores loan them out and may even tell you how to do it I would do this or the leakdown before ripping anything apart
As for the reply about popping a stock head gasket,,, at 50K mine went,,, I caught it right away and I am at 110K (miles US car) and no issues, runs great.
As far as cost for a simple repair if no other damage has been caused my estimate is as follows:
milled heads - $150
gaskets - $60
fluids (oil/coolant/filters) - $60 (one oil change to clean motor <20 miles) next oil change for actual use (I used dino for cleaning and synthetic for actual use)
tube of sealant for head bolts - $5
RTV for intake seal - $5
other gaskets $20
new head bolts?? - $30??
purchase of a tool (always end up buying a tool) $40
10% contingency
Grand total for a do it yourselfer safe estimate should actually be less
approx $400
just my $0.02
Old Jan 7, 2007 | 02:29 PM
quick fix...
i didn't really notice any oil in the coolant or vica versa, but for a quick solution my dad put something in it he picked up one day at autozone, it stopped the white smoke, so when i get in my possession, i'm going to try the leakdown test, just to see....and about the 6 pack....well with my temper and the Navy always breathing down my back, i'm gonna need a case and end up messing up more than i fix....lol
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
