head gasket
Old Aug 21, 2008 | 09:04 AM
gsxrguy17's Avatar
head gasket
anyone ever had problems getting impala head gaskets to seal?? both of mine are leaking at the back inside corner and leaking right into the lifter valley as soon as i put water in the radiator.
Old Aug 21, 2008 | 11:45 AM
Stl94LT1's Avatar
Nope, I've uses Imp SS head gaskets several times without a leak.
Old Aug 21, 2008 | 12:32 PM
slomarao's Avatar
I would check and re check everything. Chances are something isnt quite right. Many people run them for more compression.
Old Aug 21, 2008 | 12:39 PM
gsxrguy17's Avatar
I have and everything seems good. Weird that its the same spot on both. Im gonna pull the heads tonight and see what the gaskets look like.
Old Aug 21, 2008 | 02:31 PM
C5042081's Avatar
did you use tread sealant on all the head bolts?
Old Aug 21, 2008 | 09:54 PM
Stoopalini's Avatar
Were the heads milled? Perhaps the dowl pins are causing a problem.
FYI: I'm running the impy gaskets and do not have a problem either.
Thomas.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
