Which head gasket?
Old Oct 31, 2005 | 07:51 PM
Harvey's Avatar
Which head gasket?
My heads have been milled a very small amount, .005. Which head gasket should I use? Did a search and didn't find anyone with .005 milled heads and what gasket they used. Sorry, I know this is a common question. Just want to be sure I get the right stuff.
Wayne
Old Oct 31, 2005 | 08:59 PM
rskrause's Avatar
Moderator
Re: Which head gasket?
It depends what your goals are, but really a stock gasket would be fine if your motor is stock. With the milling it will raise the CR just a bit.
Rich
Old Oct 31, 2005 | 09:10 PM
FastZinTennessee's Avatar
I got a new pair of stock headgaskets when I swapped mine out. Your heads are milled such a small amount I don't think it will make much of a difference. Some guys are running the Mr. Gasket set, if I remember correctly it's very thin, like .026. If you're looking to raise the compression and get your quench area down, that would be the one to use.
Old Oct 31, 2005 | 09:13 PM
Harvey's Avatar
On the Mr. Gasket sets, I assume I will still be able to run 93 octane gas with no problems. Do I need a special intake gaskets or will stock ones do if I deceide to go with the Mr. Gasket set?
Wayne
Old Oct 31, 2005 | 09:26 PM
I have not heard of any issues using 93 octane gas and the thin gaskets. Standard intake gaskets will be fine.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
