Head gasket
Old Jul 26, 2004 | 01:59 PM
jorgez28's Avatar
Unhappy Head gasket
can you still have a blown head gasket even if there is no water in the oil?
Or smoke from the exhaust. but I do have bubles in the coolant and the car does heat up while I drive????????
Old Jul 26, 2004 | 02:13 PM
Hardee46360's Avatar
Re: Head gasket
doubt it, sounds like you just need to bleed your system completly. tokk me 3 days of the car sitting with rad cap off, They are damn hard to get the air out. By a new thermo might help
Old Jul 27, 2004 | 12:55 AM
Lt1t56's Avatar
Re: Head gasket
Try bleeding the system if you think it needs it, not hard only 2 bleeder screws.
Old Jul 27, 2004 | 05:56 PM
jorgez28's Avatar
Re: Head gasket
I did bleed the system the air came back!!!!
Old Jul 28, 2004 | 12:57 AM
Lt1t56's Avatar
Re: Head gasket
Just a guess . Possibly small head gasket leak, small enough that there is not white smoke noticable at this time until it gets worse.
Old Jul 28, 2004 | 09:14 AM
Re: Head gasket
Now that I think about it, right before my head gasket blew I did notice that I had to fill top off my fluid about once every week
Old Jul 28, 2004 | 09:37 AM
cmking26's Avatar
Re: Head gasket
Before my rebuild I had the same problem. Bleeding air out did not help but I couldn't find any coolant in oil. It was just a really small gasket leak. I took it to an old school mechanic friend and he had a ball that he held above rad cap and sucked up vapor into it, if this green fluid in it turned blue it meant it mixed with carbon monoxide, so there was a leak. Ask around about that too. But mine had all the same probs your having.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
