code 0420?
Old Jul 27, 2004 | 10:18 PM
DarkRider's Avatar
code 0420?
My computer is pulling this code, I think is has something to do with emissions, can anyone help with this. thanks
Old Jul 27, 2004 | 10:51 PM
Re: code 0420?
P0420 Three Way Catalytic Converter (TWC) system low efficiency Bank 1
Basically telling you that the PCM thinks the LH cat is not working well, based on info received from the post cat sensor on that side. Could be the cat or maybe even the sensor is giving false indications.
Old Jul 27, 2004 | 11:23 PM
DarkRider's Avatar
Re: code 0420?
I have an 02 sensor off of my obd1 car, can I throw that sensor on there and see if that is the problem, are the sensor for obd1 and 2 the same.
thanks
Old Jul 28, 2004 | 08:52 AM
Re: code 0420?
No, the connector for the rear O2s is square. Your OBD-I sensor and the front OBD-II sensor (same) have flat connectors. Try swapping your rear O2 sensors and see if the trouble follows the sensor.
Old Jul 28, 2004 | 10:25 AM
DarkRider's Avatar
Re: code 0420?
thanks shoebox, I will switch those and repost with results
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
