Head coolant passage question - important
Old Jun 4, 2007 | 09:39 PM
kgkern01's Avatar
I have a set of ported heads ready to go on, but the guy I bought them from partially welded the end coolant passages, what I need to know is whether or not I have to open them back up fully or is the partial hole enough for adequate cooling as the hole on the head is bigger than the one on the block as it is?
Here is a picture of the passages with the gasket opening traced in red marker.
Old Jun 4, 2007 | 09:42 PM
Daniel6718's Avatar
hmm good question more like why did he do it? id day have them opened back up
Old Jun 4, 2007 | 10:45 PM
kgkern01's Avatar
He did it because he was going to install them on a standard SBC, L98 I think, but never did.
Old Jun 5, 2007 | 03:57 PM
kgkern01's Avatar
Anyone else?
Old Jun 5, 2007 | 09:07 PM
HardcoreRM125's Avatar
Grind em out with a dremel, and be CAREFUL not to nick anything else in the process.
Old Jun 5, 2007 | 09:49 PM
92_RSCamaro's Avatar
Yea I agree with HardcoreRM125 about grind those out. They need to be open like stock.
Old Jun 7, 2007 | 12:14 PM
White96Z28's Avatar
Unfortunately, you should probably open it back up, and they take the heads and have them resurfaced at a machine shop. Grinding it out and slapping the heads on is just asking for a blown gasket...
Old Jun 7, 2007 | 01:41 PM
MachinistOne's Avatar
Just take it to the machine shop and they will mill out that section - then lightly lap the burrs off the edge. They should not have to re-surface the heads.
LeftoverChinese
Jan 14, 2024 03:03 PM
oldschool
Feb 9, 2016 09:21 PM
Brent94Z
Mar 21, 2002 04:44 PM
