Head coolant crossover pipe bolts question
Old Aug 16, 2007 | 06:38 AM
That Camaro Guy's Avatar
Allright, when I tore my motor apart those soft bolts on the back of the head that hold on the coolant crossover pipe on got stripped. I figure I'll go to GM to get replacement ones. My question is is there anything special to do to these bolts to keep them from leaking when I install them. Also is there a different part number for the harder version of these bolts used in the later LT1s that I could ask for when I go to the dealer? I'm building a complete new motor btw.
-Pete-
Old Aug 16, 2007 | 06:50 AM
joeSS97's Avatar
You need the four seals for the bolts.-$20.Two on each.Ask for the bolts for a 97 camaro,I dont know if they are different.Make sure you start them in by hand.
Old Aug 16, 2007 | 06:54 AM
SS RRR's Avatar
I believe those banjo bolts have been revised. The ones I received from the dealer recently were a true 14mm(???) fit and seemed to be hardened.
Seems the stock junkers were steel magnesium or almost aluminum or something similar. And yes you need the seals. Shoebox's website has the part number.
Old Aug 16, 2007 | 08:22 AM
The heads should be 15mm. I believe early, stock bolts had a smaller head and were prone to stripping. The replacement bolts and later model bolts have the larger heads.
Old Aug 16, 2007 | 02:34 PM
Thanks for the info everyone! And shoebox, nice website.
-Pete-
Old Aug 16, 2007 | 08:06 PM
MeanGreen97Z's Avatar
Ya those stockers suck man! New seals and new banjo bolts on my crossover tube actually brought down the temps on my car. I guess they were leaking and letting air in. Cheap fix!
Old Aug 16, 2007 | 10:30 PM
raroz28's Avatar
My stockers got blown out, I needed a replacement. Went to Murrays, bought a pack in the help section. They're just washers with a rubber seal. I bought the 12mm set, worked fine, no leak, dry as can be. Was free cuz my bud works there, but I think it was only 3 bucks.
MadMav
Feb 6, 2015 11:02 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 18, 2014 12:57 PM
