Head & cam removal guide
Old Feb 3, 2006 | 08:05 PM
Jeff95TA's Avatar
I put this together when I did my head and cam install. At the moment it's in two pieces in Microsoft Word. First document is the writeup, second is the labeled pictures to go with the writeup.
To keep the size down I had to compress the pictures, so they aren't really print quality. Even so the picture file is still 15MB. Best to right click & save. A few people have the big version that can be shared if interested or I can send it over AIM.
Let me know what you think. All comments are welcome. I'm sure I did some unnecessary steps or some things in a way that could have been easier!
http://home.comcast.net/~jsaccani/Je...al_Writeup.doc
http://home.comcast.net/~jsaccani/Je...l_Pictures.doc
I also have one for an engine removal.
Old Feb 3, 2006 | 09:33 PM
sabre81's Avatar
Re: Head & cam removal guide
Looks good. Thanks
So how is your car running? My setup will be VERY close to yours. I'm going with LE2 heads, LE1 cam, 1.6 pro mags, mac midlengths, hi flow cat, etc..
Old Feb 3, 2006 | 09:53 PM
Cmr0z28's Avatar
How many miles are on your motor?
That's a damn good guide you made. Props!
Old Feb 3, 2006 | 09:54 PM
Javier97Z28's Avatar
Moderator
Lots of great pictures on there, great reference points. Must have taken alot of time
Old Feb 3, 2006 | 10:09 PM
Jeff95TA's Avatar
Originally Posted by sabre81
Looks good. Thanks
About 55K on the motor and I spun a bearing after 700 with the new setup. Doing a 383 now.
Old Feb 3, 2006 | 10:16 PM
Moderator
Spun a rod bearing I take it?
Cmr0z28's Avatar
I really can't afford to spin a bearing....and my cam install is scheduled for 1 week from now. Sigh....
Old Feb 4, 2006 | 07:50 AM
Jeff95TA's Avatar
Yeah it was a rod bearing. And just because you do a cam swap doesn't mean you'll spin a bearing. Go for it.
Old Feb 4, 2006 | 07:52 AM
sabre81's Avatar
o geez. Did you change your timing set? Did you change the oil immediately after running the engine for 10 minutes on initial start? What were you spinning the motor to?
Any ideas what might have caused it? I'll be starting my heads/cam swap in a few weeks...
oldschool
Feb 9, 2016 09:21 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
NED4SPD
Sep 16, 2002 10:45 PM
