Head Bolts Tourque
Old Aug 21, 2004 | 09:33 PM
97 Z Me Go's Avatar
Head Bolts Tourque
With stock heads and gm gaskets what the TQ on the bolts.
Kyle
Old Aug 21, 2004 | 10:25 PM
Re: Head Bolts Tourque
Torque-to-yield specs:
First pass all bolts 22 lb. ft.
Second pass medium and long bolts 80°, short bolts 67°.
Old Aug 21, 2004 | 11:00 PM
97WS6SCharged's Avatar
I did mine in 3 passes, 25, 45 and 65, then checked them all 3 times before I was satisfied. No problems so far, knock on wood.
Old Aug 21, 2004 | 11:14 PM
Spinner's Avatar
I did mine like this:
Step One: 32 ft.-lbs.
Step Two: 52 ft.-lbs.
Step Three: 70 ft.-lbs.
Per trick flow's guide for 23 degree heads HERE
http://www.trickflow.com/product/che...stallation.asp
Old Aug 21, 2004 | 11:59 PM
Lt1t56's Avatar
Shoebox's method is the correct way but most people including me do a final torque of 65lbs and havent had any problems. Knocking on wood also.
Old Aug 22, 2004 | 01:35 AM
97 Z Me Go's Avatar
Im using ARP Bolts and was told because of the washers being on there you can torque them just once????
Old Aug 22, 2004 | 02:58 PM
Spinner's Avatar
Thats nuts. Head bolts are only USABLE once, but you can torque them as many times as you want to get to final specs
Old Sep 3, 2004 | 12:27 AM
97 Z Me Go's Avatar
Well my heads are sposed to be here tommarow. So i just want to make a doubble check. Use the factory method but torque ALL bolts to 65 ft lbs.
Does every single bolts get the same 65 ft lbs?
Kyle
Old Sep 3, 2004 | 08:55 AM
Kyle
If you don't like the factory specs I gave you, I guess you can do whatever you want.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
