Low coolant light
Old Sep 3, 2004 | 08:27 AM
96Jimula's Avatar
Low coolant light
Seem to have the low coolant sensor failure problem. Coolant is fine but the light stays on.
Is there a procedure for cleaning the sensor? I saw on the Shoebox sight how to remove it, but nothing that details how to clean it. I'd rather replace or clean the sensor instead of just unplugging it. Thanks!!
Old Sep 3, 2004 | 08:59 AM
Re: Low coolant light
Cleaning is just a matter of doing whatever you need to make it clean. There is not much there to clean. It does not always work, though. I cleaned mine and it still comes on at random.
Old Sep 3, 2004 | 09:31 AM
96Jimula's Avatar
How much coolant do you remove from the radiator so none spills out when you remove the sensor? Thanks!
Old Sep 3, 2004 | 09:36 AM
jim88iroc305's Avatar
look where the sensor is and drain it down to just below its level. Remove the battery for best access.
calaban
May 18, 2020 06:43 PM
silvermansteve
Mar 4, 2015 05:02 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
