Head Bolts Question
Old Feb 8, 2006 | 02:17 PM
SLeeper94Z's Avatar
Head Bolts Question
Im currently pulling the passenger side head gasket, I haver take all the head bolts out , is there anythign else holding the head on? It looked like the alternator bracket was attached to the head?
Old Feb 8, 2006 | 02:34 PM
sssalah's Avatar
Re: Head Bolts Question
Yes the bracket is attached to the head, the power steering pump must be removed to get to the two bolts that hold the bracket to the head. Make sure to remove the steam pipe at the back of the head.
Old Feb 8, 2006 | 04:28 PM
Firehawk_Dude's Avatar
Royal pain in the ***!
Old Feb 8, 2006 | 04:46 PM
97bowtie's Avatar
Removing the two banjo bolts literally took me a total of 2 minutes. It shouldn't cause you much trouble, but make sure you use the correct size wrench (I believe it's a 15mm).
Old Feb 8, 2006 | 04:51 PM
sabre81's Avatar
Or not. I removed both my heads, then tryed to take those bolts out. no go. Tryed my impact wrench... negative. finally i was able to remove the rounded bolts with a craftsman bolt out kit and a long *** breaker bar.
Old Feb 8, 2006 | 05:48 PM
OBE1 95Z28's Avatar
Shoebox has great pictures on his site:
Accessory bracket:
http://shbox.com/1/accy_brkt.jpg
Coolant tube back of the heads can be seen in this egr photo:
http://shbox.com/1/egr1.jpg
Old Feb 8, 2006 | 06:06 PM
97bowtie's Avatar
What were you doing with an impact on the bolts?? I've removed the bolts from a couple of cars with the heads on the car, with zero problems. Guess I'm just lucky.
Old Feb 8, 2006 | 08:24 PM
sabre81's Avatar
i tryed impacting them off after i was not able to get them off with normal sockets. (bolts started to be rounded off)
Old Feb 8, 2006 | 10:50 PM
If were talking about the same bolts, I also had to impact them off!
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
