Head Bolt and Valve Spring Retainer Interference
Old Jan 23, 2007 | 07:38 PM
95Blackhawk's Avatar
OK all,
I just resolved my first issue with the heads well and now I see that the #1 bolt interferes with the valve retainers on both sides of it.
I see two issues I need help on:
1. the rubbing against the retainer is giving me a false torque reading on this bolt
2. the retainer could be not seated properly and causing spring or seal problems.
Granted it is not much of an interference but you can see that it causes physical damage to the bolt head.
Thanks all for the help!
Old Jan 23, 2007 | 07:52 PM
OBE1 95Z28's Avatar
Remove the retainer and grind away the interference areas.
Old Jan 23, 2007 | 08:17 PM
UPDATE:
What did was take off the bolt and grind away the shoulder. Now my only concern is lack of accurate torque numbers because the surface area is smaller on that bolt.
Does anyone think a 5 ft-lb difference (I theorize) will make much of a difference on new ARP bolts?
Old Jan 24, 2007 | 08:52 AM
Z-RATED94's Avatar
Should have done it this way.
Old Jan 24, 2007 | 08:56 AM
95LT1conv's Avatar
from the pic it looks like the retainer is not seated properly
Old Jan 24, 2007 | 09:21 AM
OBE1 95Z28's Avatar
Originally Posted by 95Blackhawk
UPDATE:
The bolt is the critical component; the retainer will work fine with the small amount of material that needed to be removed.
Old Jan 24, 2007 | 09:46 AM
BUBBA's Avatar
And all this time I thought the retainers went on top of the springs.
Old Jan 24, 2007 | 10:46 AM
Yeah, it's the locator, not the retainer.
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
