Head bolt problem
Old Jan 13, 2004 | 05:47 PM
  #16
FireAm94's Avatar
I will be pulling my motor soon and would like to leave the harness....did you see a place to disconnect the harness so you could leave it on the motor? Sorry bout temporarily hi-jacking your thread hehe.
Joe
Old Jan 13, 2004 | 05:53 PM
  #17
ibanez6rg's Avatar
Joe
Not sure where they all go, but I'm thinking maybe just pull the harnesses off the PCM.
  #18
polcat1p's Avatar
I droped mine from the bottom, and left everyting in place. I just disconnected the 3 wires from inside ( pass side )and pulled them through the firewall, and layed the pcm on top of the motor.
You also need to disconnect the ground in the front by the coil, and the o2s. The first time i diconnected everting what a mistake .
Chad
Old Jan 13, 2004 | 05:58 PM
  #19
FireAm94's Avatar
No way in hell mine is going through the bottom (no lift). Thanx for the info guys!
Joe
Old Jan 13, 2004 | 05:59 PM
  #20
You have to unplug 4 connectors under the passenger kick panel and pull them through with the grommet into the engine compartment. With that and the pcm unbolted, you can leave the whole thing on the engine.
[edit] I did not have a lift-just my trusty floor jack.
Old Jan 13, 2004 | 09:10 PM
  #21
FireAm94's Avatar
Really? Did you find it any easier than out the top? Also how high did you have to jack the front end of the car up?
Thanx!
Joe
Old Jan 13, 2004 | 09:29 PM
  #22
polcat1p's Avatar
I'll put it to you this way. I am NOT a mechanic,and i had my engine out in 2 hrs. Best part is that i rolled it out. I have a indoor crane where i work, so lifting was not a problem. I hear of people using engine jack to lift the car. I first put all 4 tires on ramps, so i wouldnt have to lift as high. Then unbolt the 8 shocktower bolts, K- member, tranny mount, and drop the D.S, and the motor and tranny rolls out. I never did it from the top, so i dont know whats involved that way.
I left the website papers at work. Ill give them to you tomarrow so you can from pic whats involved.
Chad
Old Jan 13, 2004 | 09:44 PM
  #23
Thanx!
Joe
The front of the car is 3 feet off the ground and the back tires are up on about 8" blocks. I have not pulled one out the top of a 4th gen, so I can't compare.
Old Jan 14, 2004 | 09:09 AM
  #24
FireAm94's Avatar
How'd you get the front end up so high....safely? This does sound a bit easier than through the top and risking a cracked winshield.
Joe
Old Jan 14, 2004 | 09:27 AM
  #25
93Z286Speed's Avatar
i couldnt get the tubing off the back of my heads, so i took em out with the tubing still on there, and then took off the tubing. Was a Pita, and as for the Power stearing pump, it took me forever to figure out there were holes in that pully, i was so mad at myself after i found it. I tried alllllllllllll sorts of ways to get at that thing
Old Jan 14, 2004 | 09:44 AM
  #26
ibanez6rg's Avatar
I'm talking about the bolt behind the pump.
Old Jan 14, 2004 | 10:55 AM
  #27
Yeah, where u have to spin the pully to line it up... unless your cars different from mine, i only had ones holding the pump and bracket to the head basically
Old Jan 14, 2004 | 11:51 AM
  #28
Joe
Floor jack and carefully used spacers of wood. I slowly raised it, using the structure at the bottom of the radiator, following it with jackstands under the pads by the fenders. I have heard others say they just alternately jacked the sides of the car up.
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
