Head bolt problem
I will be pulling my motor soon and would like to leave the harness....did you see a place to disconnect the harness so you could leave it on the motor? Sorry bout temporarily hi-jacking your thread hehe.
Joe
Joe
Joe
Joe
I droped mine from the bottom, and left everyting in place. I just disconnected the 3 wires from inside ( pass side )and pulled them through the firewall, and layed the pcm on top of the motor.
You also need to disconnect the ground in the front by the coil, and the o2s. The first time i diconnected everting what a mistake .
Chad
Chad
You have to unplug 4 connectors under the passenger kick panel and pull them through with the grommet into the engine compartment. With that and the pcm unbolted, you can leave the whole thing on the engine.
[edit] I did not have a lift-just my trusty floor jack.
I'll put it to you this way. I am NOT a mechanic,and i had my engine out in 2 hrs. Best part is that i rolled it out. I have a indoor crane where i work, so lifting was not a problem. I hear of people using engine jack to lift the car. I first put all 4 tires on ramps, so i wouldnt have to lift as high. Then unbolt the 8 shocktower bolts, K- member, tranny mount, and drop the D.S, and the motor and tranny rolls out. I never did it from the top, so i dont know whats involved that way.
I left the website papers at work. Ill give them to you tomarrow so you can from pic whats involved.
Chad
Chad
Really? Did you find it any easier than out the top? Also how high did you have to jack the front end of the car up?
Thanx!
Joe
Thanx!
Joe
i couldnt get the tubing off the back of my heads, so i took em out with the tubing still on there, and then took off the tubing. Was a Pita, and as for the Power stearing pump, it took me forever to figure out there were holes in that pully, i was so mad at myself after i found it. I tried alllllllllllll sorts of ways to get at that thing
How'd you get the front end up so high....safely? This does sound a bit easier than through the top and risking a cracked winshield.
Joe
Joe
