having trouble putting in waterpump driveshaft seal!!
Old Mar 14, 2007 | 11:51 PM
AlmostfastLT1's Avatar
I am having a hard time puttin on this seal. I keep on damaging it. Any ideas or tricks to put this on. It just seems too tight!
Thanks Mark
Old Mar 14, 2007 | 11:56 PM
Bud M's Avatar
Get one of those cone shaped caps that comes on a bottle of gear lube and put it on the end of the shaft. The seal will slip off it onto the shaft without damaging the seal.
Old Mar 15, 2007 | 03:05 AM
wrd1972's Avatar
Use a tapered socket and lube that is the same OD as the shaft and stretch it. PM me if you need a seal. I have extras around.
Old Mar 15, 2007 | 09:09 AM
qboneus's Avatar
hmm. I just slipped it over the coupler to get the 'lips' to seat the proper way and then just slid the coupler on the shaft and then transferred the seal from the coupler to shaft carefully.
tal
Old Mar 15, 2007 | 09:28 AM
zlighting's Avatar
Spray the seal with a little silicone spray lubricant, and slide it evenly down the shaft. The seal is tight, because it has elastically.
Old Mar 15, 2007 | 10:02 AM
Stoopalini's Avatar
tal
Ditto... use the coupler itself as an installation tool.
Install the seal into the cover, then slide the coupler through the seal on the cover, then seat the cover, carefuly sliding it down the coupler until it seats over the waterpump driveshaft.
Thomas.
HectorM52
Jul 30, 2017 11:46 AM
Sergio
Jan 27, 2016 04:27 PM
blac94Z
15
Mar 2, 2015 12:00 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
jayvar
Feb 2, 2015 10:00 PM
