Have a question about the crank hub!!
Old Mar 20, 2004 | 12:52 PM
CeeBee94Z's Avatar
I am still having problems getting the hub off, but I am making progress I am just not sure if it is the correct progress...
My question is, does the hub actually go inside the timing cover seal? Because that appears to be what is moving when I pull on the hub. I just wanna make sure that I am doing it right before I damage anything....
Thanks guys
Old Mar 20, 2004 | 01:08 PM
ibanez6rg's Avatar
Yes, it does go inside the timing cover, through the crank seal. It will take a lot of work to get if off, but it will come. I bought a stronger bolt to thread in snout to use force against, when removing the hub.
Dave88LX's Avatar
Not sure if this helps, but when you pull off the hub you have to make sure you're pushing against the crank, and not the inside of the hub...
What I did was put the center bolt in a couple turns, then push against that. Otherwise you're going to be fighting against yourself...
Old Mar 20, 2004 | 01:10 PM
CeeBee94Z's Avatar
Yea I bought a bolt that is smaller than the hole so I can push off the crank...thanks though
Thanks guys, at least I am doing it correct now
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
1LEThumper
Jul 14, 2003 12:45 PM
