Have leaking from valve cover after install
Old Aug 25, 2007 | 05:20 PM
mrmint69's Avatar
I installed my FMU on the drivers side valve cover using the center 2 bolts. I now have a small oil leak from the spot where i bolted it on. The covers are uneven with raised area so its not sealed like before. This means some air is allowed to escape or enter. Is this bad and do i need to seal it up with rubber washers or rtv sealant? Im not sure if under the valve covers it needs to be pressurized or not.
Old Aug 29, 2007 | 10:59 PM
mrmint69's Avatar
The car is supercharged so i guess the pressure would be higher.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
ModdedNerd
Jan 29, 2015 07:23 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
