have fuel in my oil HELP
Old Jul 1, 2004 | 11:58 PM
ponykiller z28's Avatar
Shoebox narrowed my problem down to fuel in my oil (Black smoke, flooding, sudden low oil pressure, thin oil, and dip stick shows 2-3 quarts OVER FULL)
any suggestions on what causes this and how to correct it?
(can't be fuel pressure regulator cause i just replaced it)
thanks, rus
Old Jul 2, 2004 | 12:48 AM
Tair's Avatar
Leaking fuel injector? I had this happen to me recently. The car stumbled very bad, and I waited to check it out. A week later I tried to start the car and the whole starter broke in half, cause the motor was hydrolocked (fuel injector stuck open)
Old Jul 2, 2004 | 06:32 AM
The way you've described the problem elsewhere (not good to "split" threads up into multiple parts - no one know all the facts and responses), this isn't a simple problem of a single leaky injector, unless its locked wide open, and then you would hydro-lock, as in the post above. You've got something pouring fuel into the engine... excessive fuel pressure, faulty MAF reading, faulty MAP reading, spikes in the TPS voltage.
Shoebox also told you how to check for a leaking inectors and for a faulty fuel pressure regulator. Have you made those checks yet? What are the results of those checks?
Have you had a scan done on the engine? How the O2 sensors and long term fuel corrections are behaving will point to possible causes.
Old Jul 2, 2004 | 04:20 PM
i replaced the fuel pres reg and it didn't help. how do i know if it's a stuck injector? and which one is stuck? i also put a new map sensor and it didn't help anything
Old Jul 3, 2004 | 04:04 PM
Shoebox told you how to check the injectors in response to the exact same question in your other thread:
http://web.camaross.com/forums/showt...hreadid=277900
When you ask for help, and someone tries to help you, you owe them the courtesy of at least reading the response.
Old Jul 3, 2004 | 10:57 PM
i did read it i just read this post first and responded to it first
give me a break please
Old Jul 4, 2004 | 10:44 AM
Sorry, but that is what happens when you split threads.
Old Jul 4, 2004 | 01:20 PM
the problem has been pinpointed.....
i pulled the injectors out, hit the key, and tadaa , one is stuck wide open, and another comes out a little bit, and the rest, none
stuck injectors causing fuel to get in oil causing low oil pressure and engine to flood.... another job well done by shoebox
thanks everybody
Old Jul 4, 2004 | 11:07 PM
I'm simply trying to HELP you get answers. If that offends you, I'll ignore....
Sorry to iritate you.
Have a nice day.
Old Jul 5, 2004 | 12:36 PM
Have a nice day.
i understand if your trying to help me but it sounds like your trying to be a smarta$$ with the " " face behind your statement.
sorry if i misunderstood
Old Jul 5, 2004 | 12:44 PM
I guess you just don't get it..... guys like Rob/Shoebox are the first ones to help around here, and its a huge waste of time for them to post an answer and then have it ignored. He could have helped someone else, but he chose to help you. You ignored him, when he gave you the correct answer right up front.
Old Jul 5, 2004 | 10:36 PM
i never ignore anybody when they help me out on a post, so if i did i apologize
HectorM52
Jul 30, 2017 11:46 AM
Cam's maro
Mar 24, 2015 08:09 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
Wilson
Aug 20, 2002 10:36 AM
