has anyone used this cam yet??
i called comp today and this is the cam they recomended
PART NO. 07-467-8
01 INTAKE MASTER 3016
02 EXHAUST MASTER 3037
03 ENGINE LT1 280XFI HR-13
04 GRIND NUMBER LT1 280XFI HR-13
INTAKE EXHAUST
DUR @.050 230 236
.006 TAPPET LIFT 280 288
LOBE LIFT .357 .360
VALVE LIFT .576 .571 WITH 1.6 RATIO
LOBE SEPARATI 113.0
ADVANCE 4
09 VALVE TIMING OPEN CLOSE
@ .006 10 INT 31 69
11 EXH 81 27
109.0 INTAKE CENTERLINE
i told them this would be used with stock heads and i would be using nitrous with a max of a 150 shot. also if any one has any ideas for other suporting parts like springs and pushrods and timing set i should use.
thanks
brad
PART NO. 07-467-8
INTAKE EXHAUST
DUR @.050 230 236
LOBE LIFT .357 .360
LOBE SEPARATI 113.0
ADVANCE 4
@ .006 10 INT 31 69
11 EXH 81 27
thanks
brad
Re: has anyone used this cam yet??
I'm running that same cam, and love it. I was reccommended that same cam for nitrous use with relativly stock heads. I'd get it again. Just make sure your tune is right and you don't have any vacuume leaks and its pretty streetable.
I use the Beehive 915's and hardened pushrods. Stock timing set for now but I don't regulary spin it that high even though it loves it. I also did 7/16th studs, 1.6 NSA RR, and quide plates.
And just so you know.. You have the intake and exhaust lifft numbers backwards.. It's .571 In and .576 Ex
