Has anybody here sonic checked an LT1 block?
Old May 13, 2004 | 04:45 PM
AdioSS's Avatar
West South Central Moderator
Question Has anybody here sonic checked an LT1 block?
I'm wondering what the cylinder wall thickness is for a stock bore motor. Can anybody help me out?
Old May 13, 2004 | 04:52 PM
bdc95ta's Avatar
I'm almost + that shoebox has those spec's on his website.
-b
Old May 13, 2004 | 04:53 PM
AdioSS's Avatar
got a link?
Old May 13, 2004 | 05:03 PM
ibanez6rg's Avatar
http://shbox.com
Old May 13, 2004 | 05:17 PM
AdioSS's Avatar
I breifly skimmed through that page and couldn't find what I'm looking for
Old May 13, 2004 | 05:37 PM
bdc95ta's Avatar
did u look at this too???
http://shbox.com/1/engine_specs.jpg
Old May 13, 2004 | 08:37 PM
AdioSS's Avatar
yes, but it doesn't show what I'm wanting to know.
again, I'm trying to find out how thick the cylinder walls are on a stock bore LT1. In order to find this out somebody would either have to sonic check the bores or cut the bores and measure.
I've got an LT1 block that I just picked up for cheap that I was considering cutting up, but if it can take a sleeve to fix it, then I'd rather use it.
Old May 13, 2004 | 08:39 PM
Mtrhds94Z's Avatar
HE wants cylinder WALL thickness, not bore, etc..
That isn't shown on a spec chart..
Old May 14, 2004 | 12:14 AM
bdc95ta's Avatar
sorry
Old May 14, 2004 | 06:24 AM
rskrause's Avatar
Moderator
Someone else's numbers won't do you much good. Production blocks are often fairly far off spec in terms of wall thickness. That's why people check them, to see if they have "core shift" and hence determine if a large overbore is feasible. Really sophisticated builders may do an "offset bore" where the bore centerline is offset away from the "thrust" side of the piston. This leaves a thicker wall on the thrust side, where the most stress is. In any case, for an NA application you want an absolute minimum wall thickness of ~0.140", more for a boosted application, at least 0.200" and as much as 0.240" for a really high-po setup. A partial block fill will help if the thickness is marginal. I wouldn't do an LT1 more than 0.030" over without having it checked. To be clear: you can't assume that YOUR block is suitable without actually checking it.
Rich Krause
Old May 14, 2004 | 06:43 PM
Mindgame's Avatar
Thumbs up
Rich Krause
I agree with those numbers for thrust side measurement. Although I've come to prefer a minimum of .170 for an Hi-Po na build, I'm thinking .140 might be alright if the power is kept low (like 1 hp per cid).
Although I agree with Rich, these aren't my numbers, I don't have sonic check equipment, they do however jive with my talks over the years with competent builders. Should be no different from standard SBC and the LTx motors.
-Mindgame
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
