harmonic balancer
Old Apr 16, 2005 | 10:05 PM
69vette's Avatar
harmonic balancer
Should i go with an aftermarket balancer on my 383 set up or is the factory one fine? thanks
Old Apr 16, 2005 | 10:10 PM
93black-ta's Avatar
Re: harmonic balancer
i would say he factory balancer is fine for most setups. i went wth the pro products balancer for the keyed hub feature. just a little extra insurance and it only cost about $80 but its basically a stocker.
Old Apr 16, 2005 | 10:15 PM
MarkyMark's Avatar
I have the ASP one and I like it, but if you are gonna be spinning to high rpms, then it is not reccomended.
Old Apr 16, 2005 | 11:28 PM
69vette's Avatar
stock is not recomended for high rpms or asp?
Old Apr 17, 2005 | 08:29 AM
magnumv8's Avatar
I decided to go with the ATI Super Damper on mine. It isnt cheap, but I didnt want to risk using the stock one after spending thousands on a forged 383...
Old Apr 17, 2005 | 10:52 AM
How fast are you planning to go? NHRA requires an SFI-rated damper when you go under 11.00
Old Apr 17, 2005 | 03:49 PM
MarkyMark's Avatar
Im not sure about the stock one, but I know the ASP isnt good for higher rpm's...not sure how high is too high though.
Old Apr 17, 2005 | 04:09 PM
MarineReconZ28's Avatar
My buddy built a motor for his 5.0 stang and left his "slightly used" balancer on after new build. It lasted him a weekend and the balancer helped his piston go through the front of his block. Ever since that day, I've had the mindset of replacing the balancer everytime I replace the rotating assy. (Not that I ever do that though.)
Jeff1904
Jun 5, 2016 05:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
karpetcm
Aug 14, 2015 03:02 PM
bunker
Aug 1, 2015 10:10 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
