harmonic balancer
Old May 10, 2004 | 07:37 AM
DansTransAM's Avatar
harmonic balancer
a chunk of rubber is missing on my harmonic balancer and I can wiggle the metal back and forth, so i need to get a new one.
I was looking through summit and I found ones that look a lot like mine but it says small block chevy. The question is, can I use these on the Lt1?
Old May 10, 2004 | 07:48 AM
442olds's Avatar
http://www.jegs.com/cgi-bin/ncommerc...49&prmenbr=361
You need an lt-1 specific balancer. This is due to two things, the pulley for the acc. drive belt it machined into the outer ring of the balancer and the balancer is two parts a hub on the crank and the balancer itself. The Jegs page listed above if a Jegs rebranded Pioneer blanacer. Pretty good quality for a low cost setup. you can also get the keyed hub which they sell and install the key in the crank. Or you can just reuse your factory hub and put the balancer on.
Old May 10, 2004 | 07:51 AM
wow
they are $$$$
Old May 10, 2004 | 01:50 PM
Mtrhds94Z's Avatar
Yes yours is shot..
Why not post a 'wanted' and try for a good used one on here? should save some $$..
They actually rarely go bad...
Old May 10, 2004 | 02:04 PM
are most years universal? I have a 94, i found a 97 one on ebay.
here is my old one:
clearly see a chunk of rubber gone.
Old May 10, 2004 | 03:25 PM
New replacement pulleys fit 93-97s, so you should be able to use any year. The later model ones will look slightly different than your old one.
Jeff1904
Jun 5, 2016 05:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
karpetcm
Aug 14, 2015 03:02 PM
bunker
Aug 1, 2015 10:10 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
