SLP headers and burnt plug wires
Old May 8, 2004 | 12:58 PM
llafro's Avatar
Angry SLP headers and burnt plug wires
I have at least one burnt plug wire. I can see it arcing against the primary on number 5. Spraying water on the primary confirms that the cylinder isn't firing much. I may also have number 2 bad, since the water doesn't evaporate all that fast from that primary either.
What can I do to protect the plug wires?
Will an over the valve cover setup work with SLP headers? I have looked at it, and the passenger side seems a bit tight.
BRAD
Old May 8, 2004 | 01:27 PM
BPS's Avatar
BPS
with my SLP's I went over the top for all plugs except 1 and 3 which were done from the bottom.
http://www.members.shaw.ca/bps-z28/i...c/P5070371.jpg
still pretty tight
Old May 8, 2004 | 07:25 PM
sherwinZ28's Avatar
I did OTVC wires, taylor, and wont do it again. The passenger side SLP shorties on my 96 are a pain. This time I'm going as close to stock location as I can with MSD wires. After the header installation and stock wires, the car ran perfectly fine for over 20,000miles. Once I switched to OTVC Taylors the nightmares began. Good luck if you go that route, its back to stock location for me.
Old May 8, 2004 | 08:01 PM
BPS's Avatar
BPS
'96 is a dual cat set up - headers are different, OVC seems to work for my single cat setup
Old May 10, 2004 | 02:00 PM
Black_95Formula's Avatar
I have Taylor's OVC set... It seems to work fine for me wiht over 30k miles on it. BTW I have SLP shorties and just 1 cat.
Old May 10, 2004 | 02:30 PM
94formulabz's Avatar
I have my wires in the stock location with double layered Spectre (super cheap) heat shielding for added insureance. I don't think any of mine are touching anyways would be ok without heat sheilding, you just have to get them in there right.
-brent
Old May 10, 2004 | 03:36 PM
93midnightta's Avatar
i just did as&ms and they're very similar. i used msd heat wrap for all my wires as added insurance but none are touching. on the passenger side i took of the tensionor pulley and ran them through the hole there. from there it's just up from the motor mount and none are even close to touching. on the drivers side they go through the stock location and i have them snugged as close to the block as possible. they only close one is 6 and it's still 1/2" away. give that a shot...
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
jim88iroc305
Aug 13, 2002 09:24 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
