Harder install clutch or headers
Old Aug 4, 2003 | 05:53 PM
fastBlack96z's Avatar
I have done the headers and was wondering which is harder the clucth install or the header install. Also are there any special tools needed? I know you need a 3ft extention but is there any thing else.
Thanks for any advice
Old Aug 4, 2003 | 06:04 PM
94 CAMRO Z28's Avatar
I have done both. I would have to say the headers were more time consuming and harder to do. Now that I have had them off and on a couple of times Im much quicker but the clutch really wasn't bad at all. I had trouble the first time around trying to get the clutch fork to grab the throwout bearing. Everytime I pushed the clutch pedal the fork would fall off the clutch and get jammed. I couldn't figure out the problem so I dropped the tranny, driveshaft, etc. and checked it all out. First time around it took me about a day to do by myself along with a couple runs into town for tools. The 2nd time around I had the tranny down, everything taken off and put back together within 4 hours. If you have a friend help you I would say you could do a clutch job in a couple hours if you work quick. No real special tools were needed but I had to buy a 6pt. socket for the flywheel and a breaker bar to help get the bolts loose. Also a tranny jack would be helpful but I just used a piece of wood balanced on the jack under the tranny. It wasn't to bad at all..
Aaron
Old Aug 4, 2003 | 06:38 PM
thanks. Looks like I'll be doing this soon
Old Aug 4, 2003 | 06:50 PM
No problem, good luck and if you do get stuck, theres plenty of people on here that are willing to help you out.
Aaron
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
dmcdonald96
Jan 30, 2015 06:46 AM
ro2207
Dec 4, 2014 06:18 PM
