hard time removing crank hub
i am having a hard time removing the crank hub on my 95 z. i have 2 diffrent types of removal tools and they both seem like they are not working. the bolt is out of the center of the hub and the balancer is off. is there any pics or diagrams that can show how it comes off. I am in the middle of a heads and cam job. car is automatic
Re: hard time removing crank hub
You may be stipping the crank threads. Is the hub moving at all?
I removed my hub using a balancer/steering wheel removal tool. I removed the washer/spacer from the hub center bolt and threaded the bolt back into the hole about 4-5 threads. I used this bolt to "push" against. The hub came out came out really easily. Just make sure that you don't bottom out on the hub bolt. If the hub isn't moving something isn't right.
It comes off with a puller. What you do is take a harmonic balancer puller, not a jaw puller. Screw the bolts in the holes,if you have to use smaller bolts and nuts so they fit threw the tool. Take a strong but skinny bolt or punch and put it in the crank bolt hole, but make sure the bolt is long enought to stick out past the hub. Then put the tool and and put it against the bolt or punch and crank away.
I used a three jaw puller on mine and did as already mentioned with threading the bolt back in about half way. Don't try to start pulling on it with only a couple of threads screwed in. Once you get it busted loose it will come off pretty easy ( you'll have to use the puller the whole way off though) good luck .
I used a 3 jaw puller and pulled against an extension for a small socket wrench which I put in instead of the crank bolt to avoid damaging the threads...it came out but very very slow..if you're going to change the gasket anyway you could heat it up as well then it will slip off easier.
i cant get it busted loose without the crank spinning.( heads are off the car )
maybe i need more leverage. i have tryed each way people have told me. is there anyway i can prevent the crank from spinning?
Les
Originally Posted by 1racerdude
Go to Shoeboxe's sit and search.You will find all the instructions you need.
The pulley comes off with 3 bolt's. The hub has a "built in washer" in the bore,hence the need to put the bolt back in a few threads to pull it.A 3 hole(chicken foot) puller will work with the weight removed.
ive got it off with the crows foot type puller and i jammed a big screw driver in there to stop it from spinning and it came out little by little. i just wanted to say thanks for all the help and suggestions. I even pulled the cam out tonight as well. thanks again
- frank -
- frank -
When you put it back,get everything clean and put the hub in the oven at 250* for about an hour or so. Take it with gloves and haul *** to the car and install,put the crank bolt in and tighten while it is hot.It should push on by hand,just make sure it is on all the way.
Your lucky, I couldn't even get the balancer off easily or at all with it on the car.
I'll just wait to do it when the engine is out of the car.Nothing has been real easy with this car but I sure as hell am a lot faster when I got to take something off to get to something else. It always seems something else has to come off to get to what you need.
Chrisdude
Jul 25, 2002 05:54 PM
