Hard starting.
Old Oct 19, 2003 | 03:23 AM
revtime's Avatar
Hard starting.
Heres one for you guys.
Car takes 2 tries to start, always starts on second try.
Fuel pump is new, just changed the FPR, IAC, TPS, MAP, O2s are all new, EGR is deleted and blocked off.
Opti is new, plugs and wires are basically new just 4k on them.
Would a leaky injector cause this?
I am at a loss as to the problem.
Injectors is all I can figure.
Old Oct 19, 2003 | 03:29 AM
Transamdriver's Avatar
Thumbs up
Leaky injector or your initial timing is too advanced somehow.
Old Oct 19, 2003 | 11:17 PM
revtime's Avatar
I am going to go ahead and put some new injectors in and see what happens, I think the dang motor might just be getting old.
Old Oct 19, 2003 | 11:23 PM
Fast96WS6's Avatar
Ive been having the same problem.
Last week it wouldnt start at all with the new programed pcm (obdI converted). So I had to swap in the older pcm for it to start. I also had a high load misfire so i changed my opti and the starting problem went away slightly. But it still takes a long time to start with the new opti, esp on cold days with the new pcm. Could this be because the initial timing in the new program is too advanced?
Old Oct 19, 2003 | 11:33 PM
revtime's Avatar
Its a possibility in your case.
My program has been in the car for years (Ed Wright) and it always started fine.
I get the headers, new tranny, and stall in and it does this 2 tries to start deal.
I know its getting up there in mileage so I am replacing old parts, injectors are next on the list.
93 RedBird
Nov 15, 2015 08:24 AM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
