Hard to start, won't idle and unable to get codes.
Old Feb 10, 2005 | 10:24 AM
max929's Avatar
Car starts but with giving it gas. It will idle real low and eventually cut off.
I tried hooking up my scan tool but it's states car not responding. I then used a jumper wire (93Z) to A and B and still nothing. The Service Engine Soon is on. Any ideas?
Old Feb 10, 2005 | 11:15 AM
madwolf's Avatar
Re: Hard to start, won't idle and unable to get codes.
You've given us pretty much no information about your car and modifications.
If you have an aftermarket chip in your car, try taking it out and putting the stock one in to see if it fixes it.
Old Feb 10, 2005 | 01:08 PM
max929's Avatar
The chip is from pcmforless. The car has ported heads, larger intake/exhaust valves, Slp mid length headers, no cat, flowmaster exhaust.
I've run the scan tool on it before with the chip with no problems, but I will remove it to see if that does the trick to getting the codes.
Man from one day to the next this problem just jumped on me, I'm wondering
if it's the fuel pump or my opti.
Old Feb 10, 2005 | 02:27 PM
indieaz's Avatar
Might want to get a fuel pressure guage and see what shows up after you start it...sounds like it's probably fuel related to me.
Gtpguy
Jan 26, 2015 04:50 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Britbilly
Jan 7, 2015 08:49 PM
jayblev95
Dec 1, 2014 06:55 AM
Lions3
Apr 11, 2003 10:55 AM
