Hard to start when cold
Old Mar 16, 2013 | 10:34 PM
Rij1's Avatar
My car had a cold starting problem that I thought had to do with the vats cause the light was on. I fixed the vats with the bypass but that didnt fix the starting problem i'm having. When the car is cold like in the morning or after sitting half a day the engine will not start like normal. I have to crank the engine for about 30-45 seconds. sometimes the engine trys to start but doesnt till awhile of cranking. I changed the fuel pump, filter.
Old Mar 17, 2013 | 08:28 PM
Rij1's Avatar
Re: Hard to start when cold
Does anyone have any possible causes for this problem?
Old Mar 17, 2013 | 08:46 PM
slick1hunting's Avatar
I would check the fuel pressure and specifically for leakdown. Might also want to check the vacuum line from the fpr for raw fuel. If you allow the fuel pump to prime a couple times before trying to fire it up and if it fires up will also help show its a leakdown issue.
Posted from Camaroz28.com App for Android
Old Mar 18, 2013 | 04:11 PM
parkers Z28's Avatar
You could have leaking injectors ... next time you start the car up hold the gas pedal to the floor
Turn the key and see if it cranks faster
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 23, 2015 01:13 PM
Britbilly
Jan 7, 2015 08:49 PM
jayblev95
Dec 1, 2014 06:55 AM
