Hard Start and stall at idle
Old Apr 25, 2004 | 11:31 AM
93TArunner's Avatar
I just did opti / wp swap and the car is very hard to start.. it cranks very very slowly for the first 2 tries and the lights dim.. and then it'll just fire right up... Its just fine while driving xcellent actually... but at idle it'll try n hold 900 ish rpm but every couple seconds drop to round 625 for a split second and almost stall and does stall sometimes. Could a bad plug wire cause this???? Because the old opti had corrosion in cyl8 terminal and i haven't got arround to doing the wires yet. SOO happy not to have that 3000 rmp stumble anymore from the opti but this stalling isn't fun now....
Old Apr 25, 2004 | 11:53 AM
DrunkenMantis's Avatar
Maybe a failing alternator thats causing the stalling?
Old Apr 25, 2004 | 01:05 PM
93TArunner's Avatar
When I was replacing the belt it felt like the alt did hav some play in the pulley. and new belt also alot more tension on it
camy 1993
Feb 3, 2015 06:26 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
jayblev95
Dec 1, 2014 06:55 AM
