Hard Start Only When Cool What Can It Be?
Old Feb 24, 2003 | 08:54 AM
94SLUG's Avatar
Question Hard Start Only When Cool What Can It Be?
Well i have new plug wires/ plugs. Fuel pressure is good. Just had the module on the coil go out so i replaced it. Opti is 1 month old. Still have a hard start onlywhen its cool.
Old Feb 24, 2003 | 09:09 AM
Lions3's Avatar
How cold are we talking?
Old Feb 24, 2003 | 09:12 AM
Gripenfelter's Avatar
Hard start as in turns over slow?
Old Feb 24, 2003 | 09:36 AM
gd1996ss's Avatar
I bought my 93 formula like a month ago. Started fine when I looked at it, and was ok when I drove it home. But it got really cold, like single didgits, and it did the same thing. It would crank over fine, but just didn't want to go. After a few minutes it started. So I'd love to know what would cause this. But I'll never drive it when its this cold out, so its no big deal really.
Old Feb 24, 2003 | 09:38 AM
94SLUG's Avatar
Turns fast cranks after 5-10 seconds. Hard start after 30 min no runing.
Old Feb 24, 2003 | 10:19 AM
drop top steve's Avatar
Sounds like lose of fuel pressure. Can you hear the fuel pump run for a few seconds when you first turn the ignition on? Try truning the key on and off three or four times to prime the system. Check your fuel filter. Also check the coolant temp sensor.
Old Feb 24, 2003 | 10:26 AM
Lions3's Avatar
When it's REALLY cold, it's going to be hard for the car to start. It's fairly natural, wouldn't you think? I wouldn't think much of it, because I know that if it get's to be in the - side of the thermometer, everything get's sluggish.
Old Feb 24, 2003 | 11:43 AM
WS6T3RROR's Avatar
i'd check the coil, thats what mine was. look around the housing for any white looking areas where stress and heat have damaged the case. if it seems to do it when its damp out too rather than just really cold try swapping in another coil and see if it goes away. mine was arcing when it finally left me stranded. and was only when the car was cold but after i got it started it would run like a champ until i shut it off again. could be this, just my .02
94SLUG's Avatar
the fuel pressure is good and yes i hear the pump before starting. Even if i cycle the key 3 times it takes 5-10 seconds to start. The fuel filter is new. Now im starting to think AFPR???? Ah yes good idea ill try CT sensor. I live in Miami its never cold here so thats never a problem.
Old Feb 24, 2003 | 02:00 PM
94SLUG's Avatar
TTT ANYONE!
Old Feb 24, 2003 | 02:56 PM
JohnD's Avatar
If the cold start sensor is bad, the pcm won't richen the mixture and it can be hard to start when cold. A quick check is sometime when it is really cold, put a couple of tablespoons of gas in the intake manifold and if it starts right up, that is probably it.
Old Feb 25, 2003 | 01:39 AM
thebrainhart's Avatar
I'd check plug wires.
Mine used to have hard starts in the cold. Usually only when I didn't wait for the fuel pump to send it's fuel after turning the ignition on. I even completely flooded the engine once, for a while, trying to get it to start. Usually if I waited, then tried starting, it would after a few seconds of cranking.
I changed the plug wires and plugs, and now it starts fine, even if I don't wait.
Noenav
Mar 1, 2019 07:38 AM
HectorM52
Jul 30, 2017 11:46 AM
Alex Barnes
Jan 24, 2015 10:21 PM
