Hard to start
Old Jan 29, 2007 | 02:25 PM
jsetzer's Avatar
Hard to start
This is something I have dealt with for a year, just wanting some input.
My car always starts. This is not a battery or alt problem.
When the car is cold (like cold outside below 70) it usually fires first thing. If its warmed up or temps outside are warmer I have to crack the throttle a tiny bit and then it fires right up.
I have drilled the little hole between the throttle blades several times now at I know its getting rather large because the IAC takes a sec to bring the idle down when its cold out.
My thoughts.
Still choking, needs more air?
Fuel related, I have 36# set to @ 39.x
Nature of the beast? The motor has a lot of compression. 13:1+ Maybe its just harder to turn over warm because the pistons/rings are expanded.
I am on my factory starter, maybe an lt4 with a bit more oomph would help?
Old Jan 30, 2007 | 09:30 AM
jsetzer's Avatar
Can a starter be worn out, but still working? Thought they just went bad.
Old Jan 30, 2007 | 11:05 AM
jlmeraz's Avatar
interested as well.. bump
armedtrigger
Feb 24, 2015 08:30 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
jayblev95
Dec 1, 2014 06:55 AM
